Troll
Fastest 50cc in Upstate SC
Post by Troll on Jul 9, 2014 13:28:36 GMT -5
About ready to throw in the towel on this motor. Blew out the damn oil seal AGAIN, the one behind the variator. No warning signs or anything, I just check under the CVT cover two days ago and it was dry. Today on my way to work not even 2 miles from the house the rpms shot up to 9 grand and that's what happened last time. So I shut it down and sure enough the oil started to pour out of the CVT cover. If this shit keeps up I'm going back to the stock motor it looks like.
Post by 90GTVert on Jul 9, 2014 16:25:19 GMT -5
How is your crankcase vented? No lines pinched or anything? Still got good compression?
Troll
Post by Troll on Jul 9, 2014 20:10:36 GMT -5
Compression seems fine, it starts like a champ and no running issues. The only vent us the valve cover and it's not pinched cause that the first thing I always check when I put the seat on always. Thinking about adding the vent tube to that replaces the dipstick to see if that helps.
Post by dude on Jul 9, 2014 22:45:28 GMT -5
About ready to throw in the towel on this motor. Blew out the damn oil seal AGAIN, the one behind the variator. No warning signs or anything, I just check under the CVT cover two days ago and it was dry. Today on my way to work not even 2 miles from the house the rpms shot up to 9 grand and that's what happened last time. So I shut it down and sure enough the oil started to pour out of the CVT cover. If this shit keeps up I'm going back to the stock motor it looks like. I had a scooter do the same thing. But my vent tube was smashed. (My fault) instead of dipstick maybe a extra vavle cover vent?
Troll
Post by Troll on Jul 10, 2014 9:35:30 GMT -5
I'll double check, about to go replace the seal, just glad I bought an extra.
Troll
Post by Troll on Jul 10, 2014 10:58:26 GMT -5
So I replaced the seal and just like before it is getting sucked towards the motor and resting against the timing gear. Any ideas on what could cause that, the best tube is clear and not pinched but if it was wouldn't it be popping the seal outwards? Never had this problem with seals so it has me stumped.
Post by dude on Jul 10, 2014 23:04:35 GMT -5
Just thinking when you remove the dipstick it blow outwards when running. But seal is sucking in on the timing chain. You change the seal on the stator side. I would make a vent on the stator side that holds the seal towards the top of that casing then thru the top like your stator wires with a filter up higher in the frame.
Troll
Post by Troll on Jul 11, 2014 0:00:38 GMT -5
I'll check in the morning. When I replaced the seal on the stator side everything seated up good and tight.
Troll
Post by Troll on Jul 11, 2014 0:09:16 GMT -5
Post by 90GTVert on Jul 11, 2014 4:56:00 GMT -5
Worth a shot. Whether it's sucking in or blowing out seals I'd think giving the +/- pressure a place to go could help. You may wanna go with a filter on the end of it rather than just that little aluminum piece if it works.
Troll
Post by Troll on Jul 11, 2014 10:28:39 GMT -5
Dude, I pulled the dipstick while it was running and almost got attacked by oil the came out the damn hole. Thinking you just set me up, lol.
Troll
Post by Troll on Jul 12, 2014 13:27:36 GMT -5
My crank is shot, got to work yesterday and something didn't seem right so took the CVT cover off and grabbed the drive plate and it wiggled, went to turn it to turn the crank and it just free spun without the crank moving. So today I took it off and the splines on the plate and crank are stripped. I'll post pictures as soon as I can
Post by 90GTVert on Jul 12, 2014 16:20:17 GMT -5
Ouch. How many miles are on it at this point?
Troll
Post by Troll on Jul 12, 2014 18:42:18 GMT -5
Almost 6000 km
Post by dude on Jul 12, 2014 22:54:03 GMT -5
Hate to hear that.
