Post by jloi on Apr 24, 2019 12:24:17 GMT -5
hi everybody. I stripped the scooter yesterday and cleaned it up real good in prep. for conversion to naked & I want to rewire everything and add the LED lights I bought at Northern tools and also I want to convert the gauges to digital . I want to keep the digital conversion as simple as I can. Nothing fancy, expensive or elaborate ; but I would like to find something that incorporates all of the signal lights , turn signals ,switches etc. into one panel if I can; at least as many as possible anyway.
I've been looking on ebay and the web all over but don't know what is the latest in tech gear . Can anybody provide any links, ideas, sites, etc. to check out ?
Kind of a shame since I recently bought this new speedo lens ... Tip - never pay for "expedited" shipping from China . I think it took twice as long - about 5 weeks and was 15-17 dollars more . That's about a $36.00 lens . I didn't have any thoughts of converting anything at that time . I'm wondering if anyone has used bullet connectors for scooter /cycle wiring as I want to do away with these bulky pin connectors that crack etc. over time . Instead of completely rewiring , which doesn't really seem necessary maybe I'll just replace the pin connectors with soldered bullet connections. I would really appreciate any input or links from anyone with experience in this kind of stuff .
Things I have done to this scooter in the 3 years I've had it.
new rotor and front caliper and bearing
rear brakes and wheel bearing 2 new tires
new rear brake cable
new throttle cable
all new switches
new ignition switch new extra large mirrors new swing arm new speedo lens
new carb new drive belt new motor
new rear wheel and tire new muffler
new header pipe
Post by jackrides on Apr 24, 2019 12:36:31 GMT -5
Bullet connectors are cool with a few additions. Wire into connector must have shrink tubing over the junction, 1 is good, two layers is better. Wires should have a little dielectric grease on the ends before crimping. (Every auto parts store sells it cheap.)Female end should point down to keep water out. Connector ends should have a little dielectric grease on them.
Post by jloi on Apr 24, 2019 13:34:20 GMT -5
all great points , thanks a lot.
Post by oldgeek on Apr 24, 2019 21:32:41 GMT -5
Neked scoots are EZ er to work on, that's for sure. I love mine. The Trail Tech Vapor cluster does some of the things you are looking for. I built a wiring harness from scratch for my scoot, it looks very sketchy but I like it that way. I also converted from a bunch of switches mounted in the panels like yours, to motorcycle style switches at the grips. Took an angle grinder to anything that was not absolutely needed on the frame. There is no ignition switch or steering lock either. This is hands down my favorite scoot to ride, and I have had quite a few to choose from in my time. This is not the best picture of it, but you can see many of the things I did. If you think it looks like poo its ok, that is the reaction I was going for.
Post by jloi on Apr 25, 2019 10:47:46 GMT -5
Nah. No poo here. I'm sure it'll look great when you're done . Is that a modified / custom floorboard ?
I'm thinking of some sheet aluminum ; 24"x24" just under 1/8" thick maybe 3/32nds for about $40.00 for floorboard material; not sure what gauge that is . Then I can cover it with some kind of rubber and screw it down to the alum. . cut a hole for battery box and screw that down too. I'm still hunting online for JUST a tach and speedometer gauge but I want a digital one . I don't need GPS and all the other stuff that comes with them these days .
I think I want to put a partial plexiglass skirt on each side below the seat and around the back . I may try to use same material for surrounding the frame coming down from the handlebars too . This seems workable with lots of rubber washers and grommets . What do you think ?
This frame has so many posts/ standoffs it should be pretty easy to attach material to it.
Wish I had one of those lifts . Nice to work on it up off the ground. You an A/C guy ?
Post by jloi on Jun 16, 2019 18:42:25 GMT -5
Update on conversion headway- a while back I also got rid of emission pipe on valve cover and blocked it off. just finished putting new stem and steering column bearings in . 1st real conversion thing after removing all plastic except front fender and instrument cluster was making and adding new stainless plate to mount new lights , horn ,and rectifier.Placed slab of silicone rubber underneath it to try to absorb vibration; don't know if it helps- still vibrates so this is just temp . I'll make a beefier version . Even tho it's off topic I couldn't resist the last pik cause he/she was there at the time I was doing this work. I wrapped things up one evening and was sitting in the garage door opening , just out of sight in pic, when I heard a flutter and caught some movement up high on my right . I got up and slowly peaked outside on the roof. This big guy ? was sitting there so I ran and got my phone. He/she let me take about5 pix and then he flew right across the street and I walked over and took some more but they didn't turn out like this one. Very cool. Ominous ? who knows ? about 3.5 ft. wingspan I think only scooter - stock -2014 TaoTao ATM EVO 150cc long case QMJ 157
Post by 90GTVert on Jun 19, 2019 15:39:45 GMT -5
I have used rubber mat or grommets with light mounts in the past, but but had better results just making things beefy enough as you said. I've used rubber to try to isolate lights from the vibrations after having lights fail, but I don't think I accomplished much. The worst of my issues were when LED spot lights were a bit newer. Hopefully they're making them better than they used to.
Post by jloi on Jun 20, 2019 15:48:57 GMT -5
So , 90 GTVert ...
did beefing things up help much ? I might waste some more slab silicone rubber putting some right behind the "Y" mount thingy that bolts directly to the main column ; whenever I do beef up the mount plate for lights etc. .
Post by 90GTVert on Jun 24, 2019 16:55:59 GMT -5
I made my current headlight light bracket from 1/8" steel and it's bolted directly to the frame. So far so good. Mine also stays pretty narrow. Thinner materials and longer distances from center will likely exaggerate any flex/vibration.
Post by jloi on Jun 24, 2019 21:18:01 GMT -5
Thanks a lot. I will make sure Igo at least 1/8" thick. I can get sheet aluminum cheap at a local place .
Post by 90GTVert on Jun 25, 2019 7:35:48 GMT -5
Post by jloi on Jun 25, 2019 11:25:13 GMT -5
I wonder if 1/4' aluminum would be ok just for a base plate by itself to mount everything onto and underneath . I don't have an actual headlight yet .So I'm not fabbing an actual headlight bracket yet . That money is down the road for me .
This local place has sheet steel too. I just thought alum. would be lighter .
Also , no welding here . Bummer.
Yeah , I agree the lights are a little wide right now . Those little square ambers are fine for nite but worthless in daytime . I'll do more looking for something I can mount back to back for 360 line of sight .
I might have to hold off scooter parts buying for a while and save money instead . I haven't figured out the running rich problem yet but I can't keep endlessly feeding money into it . Before I continue on conversion, front lights etc. , and rear turn lights too, I need to get it to run right . I'm afraid I'm gonna burn up the rings , and all the bearings etc. , if I keep driving it with these too rich conditions .
Post by 90GTVert on Jun 25, 2019 17:26:18 GMT -5
For right now, and prob for free... move the horn. Move both headlights in to meet at center and move the signals in right up against them. That would have to help some with flex/vibration and likely for just time.
Post by jloi on Jun 25, 2019 19:46:20 GMT -5
ok. got it
PDub
Ann Arbor MEEEEEchigan
Post by PDub on Jul 4, 2019 20:07:39 GMT -5
You can bend steel and maintain its integrity, where aluminum with sharp bends will become brittle. So you could fabricate a very similar bracket to Brent's by cutting and bending steel (use a vise and hammer -- make a cardboard template first).
(And cool owl!)
