Post by FrankenMech on Dec 31, 2019 6:41:10 GMT -5
Filthy surgeons broke one of my neck terminals with that damn dirty endoscope.
The horrors never cease, the social workers are after me in a very unhelpful way.
Post by jloi on Dec 31, 2019 6:45:43 GMT -5
maybe you'll find some on Ebay
Post by jloi on Dec 31, 2019 6:46:55 GMT -5
you need Dr Abbynormal
Post by jloi on Jan 3, 2020 0:55:29 GMT -5
Post by jloi on Jan 7, 2020 19:28:25 GMT -5
Post by jloi on Jan 8, 2020 22:56:10 GMT -5
Post by jloi on Jan 11, 2020 14:26:04 GMT -5
Post by jloi on Jan 11, 2020 14:32:08 GMT -5
if the paint adheres well and doesn't flake off , I'll be happy .
I'm just gonna leave the red gasket oversized on the one side . If I tried to cut it I would end up taking some of the paint off the factory ring with my razor knife . I'd rather just leave it .
Post by jbjhillbilly on Jan 12, 2020 13:33:52 GMT -5
Looking good! You’re doing some fun work on this bike. You could tape the edge so you won’t scratch it. Maybe even use your nibbler to cut it (at least I thought I saw one in your pics). Try keeping you paint warmed up in hot water. Use two cans and alternate between them when one starts to cool down. A pan of water on a hot plate is great for this.
Post by jloi on Jan 12, 2020 13:39:19 GMT -5
got the new handlebar switches on this morning with just a little bit of finagling and one totally unnecessary new hole drilled in the underside of the handlebar. ended up just cutting off some more of the left side grip . now it's time to get back to sorting out the rest of this old harness and trying to semi-duplicate it .
Post by jloi on Jan 12, 2020 13:48:51 GMT -5
jbjhillbilly
aw heck, I wish I had known about the warm water for the paint before I primed it. the black finish coat went well, no problems at all; but I didn't shake the primer enough as I was spraying and it came out rough. started spitting . I'll live with it. I appreciate you advice ; I don't expect to be painting anything else now. I did spray some primer into a little plastic thing and dabbed some paint on the new hole I drilled in the handlebar- that I didn't even need .
Post by FrankenMech on Jan 12, 2020 14:58:09 GMT -5
Paint cans can blow up if they get too warm (dangerous, big mess, injuries). Use a sharpie to trace a pattern on the rubber then remove the ring and cut the rubber.
Post by jloi on Jan 13, 2020 14:37:22 GMT -5
re-did this last nite . slow day .didn't do much on it. trying to get the wiring diagram in my head good.
Post by jackrides on Jan 14, 2020 17:29:41 GMT -5
Put dielectric grease on the fuse.
Post by jloi on Jan 14, 2020 23:17:23 GMT -5
ok Jack ; thanks. I have a BIG tube
