Malaguti F12 LC Stage 6 StreetRacce 70cc
Mar 8, 2020 0:37:13 GMT -5
90GTVert, 190mech, and 9 more like this
Post by krisgenchev on Mar 8, 2020 0:37:13 GMT -5
Hi everyone, my name is Kristian. I will give you a little information about myself . I am currently working at a Scooter Shop , i won't mention any names, i am originally from Europe where we have all kind of variety of 2 stroke minarelli engine based scooters. I used to own Yamaha Aerox , and a Yamaha Neos. Since i live in a US (its been a while now) i owned a Aprila Rally minerelli and a TGB Bullet. I just got my hands on 2 Malaguti's F12. One of them is a RED Ducatti replica AC with rear drum brake with only 600 miles its 2002, unfortunately it has been dropped but i hope to be able to repair the damages and bring it back to perfect condition. The second one is the updated body style with the longer seat and rear passenger handles under the seat , its 2004 LC 2 disc brakes, its kinda beat up with 3000 miles on it, currently has from its previous owner Polini Sport with TK Exhaust and 17.5mm Dellorto carburator. Back home i had build my Yamaha Neos with similar set up so i am gonna try to do it again. I will put the a list of all the parts i had ordered 2 days ago straight from Germany so it will take like 1-2 weeks. Since the place i am working at its seasonal we are currently closed and i have access to the workshop, the only issue is that there is brand new scooters in boxes ready to be put together before i can even think to start putting my scooters apart, simply because there is no room. I am hoping to get the parts by the end of the month and to start the project as soon as possible.
Project goal:
Take the disc brake minarelli case from the newer malaguti , take the radiators and the water pump assembly , take the rear disc brake and rim . All these parts will be installed on the red scooter since its in very good condition having only 600 miles. When i am done with that i will take the 600 mile AC engine from the red one and put it on the gray one, that way i still have 2 perfectly running bikes. So here is the parts list, i will copy my invoice:
STAGE6 BRAKE PADS SPORT TYPE S10
STR8 GRIPS "MOTOCROSS"
TRANSMISSION COVER DRESS-UP SCREWS RED
STAGE6 WATER PUMP RACING +40% MINARELLI LC (YAMAHA AEROX) MATTE BLACK
STAGE6 CYLINDER KIT 70CC STREETRACE CAST IRON MINARELLI HORIZONTAL LC
STAGE6 JET KIT (10) DELL'ORTO (D=6MM)
MALOSSI TORQUE SPRING YAMAHA AEROX / BW'S
ADAPTOR FOR STAGE6 EGT & POWER TEST BRACKET MIRROR
EXHAUST STUD BOLT SET NARAKU INCL. NUTS - M6X32MM
CENTRE STAND RMS, MALAGUTI F12 / F15 / CENTRO
TORQUE DRIVER MALOSSI (107MM)
PRIMARY GEAR KIT TOP PERFORMANCES 15/50 (1:3.33)
SILENTBLOC BUSH FOR SHOCK ABSORBER MOUNTING MINARELLI
CYLINDER STUD BOLT M7X1.00 L. 118MM (X1)
WATER PUMP REPAIR KIT MINARELLI
STAGE6 TACHOMETER / TEMPERATURE MINI MK2
POLINI CYLINDER GASKET SET 70CC CAST IRON YAMAHA AEROX / MBK NITRO (MINARELLI LC)
STAGE6 CRANKSHAFT HPC MKII PISTON PIN=10MM YAMAHA AEROX
MALOSSI X SPECIAL KEVLAR BELT
STAGE6 PULLEY / DRIVE FACE RACING CNC MINARELLI / CHINA 2-STROKE
MULTIVAR MALOSSI
STAGE6 ROLLER WEIGHT KIT
CLUTCH STAGE6 TORQUE CONTROL MKII (107MM) MINARELLI
STAGE6 CLUTCH BELL RACING WING COOLER 107MM MINARELLI / CHINA 2-STROKE
EXHAUST YASUNI R BLACK EDITION 40TH MINARELLI HORIZONTAL (YAMAHA AEROX)
POLINI CRANKSHAFT BEARINGS + OIL SEALS MBK BOOSTER / NITRO
CHOKE CABLE POLINI CHOKE LEVER WITH CABLE
CONVERSION KIT TO MANUAL CHOKE DELLORTO
BUMPERS FOR WATER PUMP MINARELLI
REED VALVE GASKET SCOOTERS MINARELLI HORIZONTAL / APRILIA / SUZUKI / CHINA 2-STROKE
RACING AIR FILTER POLINI 90° SHORT, SMALL
STAGE6 REED VALVE VITON MINARELLI
MANUAL CHOKE (LEVER) FOR CARBURETOR PHVA/PHVB
I will post pictures ones i get the parts, and will try to make as many pictures as i can during the install.
Project goal:
MULTIVAR MALOSSI
