Post by aeroxbud on Jan 13, 2021 17:00:40 GMT -5
On no. Premix time?
Post by rehabkymco on Jan 16, 2021 16:35:58 GMT -5
Yes sir. Not playing around this time.
Post by aeroxbud on Jan 16, 2021 17:48:16 GMT -5
I use one of the mixing bottles. Makes it easy. There are also free apps, or even a two stroke oil calculator on this site.
Post by rehabkymco on Jan 20, 2021 4:54:57 GMT -5
Found out the other day that you (or maybe just me)can't just pull the cases apart by hand. So in the effort to do things right, I just ordered case/crank tools from Ebay. Also picked up a TPR 122mm rear pulley. And have planned for next week to order a Malossi or rear pulley spacer, a Malossi Xspecial #6112741 (796x16.5x30) belt and the Stage6 dashboard from ScooterTuning.
Which bring me to a question, is anyone else using the Stage6 or Koso db02r or db03 dash. And am I going to need extensions for the temp sensors to reach the engine.
Post by rehabkymco on Jan 23, 2021 9:09:21 GMT -5
Crank tool should be here today. Rear pulley by Monday. I am thinking that I need to make a pressure tester. Or maybe just have to ask one of these nice locals if they would do it for me. Also I will be able to have some pictures of everything as well.
Post by rehabkymco on Jan 25, 2021 17:42:08 GMT -5
Woulda had this done already but imma master procrastinator. But this is the reason the CPI engine give up. Both crank bearings give out. Gonna do some pondering if I really wanna trench these cases or just leave it be and drop the new crank and bearings in it.
Post by rehabkymco on Jan 25, 2021 17:43:48 GMT -5
Thinking if I do an thg trenching itll be on the big side and will be on the mild side.
Post by captincvmn on Jan 25, 2021 17:43:49 GMT -5
Your crank bearings look like my X-wrist pin bearings.
Post by rehabkymco on Jan 25, 2021 17:44:37 GMT -5
Your crank bearings look like my X-wrist pin bearings. They are pretty bad. But no oil will do that
Post by aeroxbud on Jan 25, 2021 18:12:28 GMT -5
It came apart alright in the end. So much easier with the proper tools. š
Post by rehabkymco on Jan 25, 2021 18:14:51 GMT -5
It came apart alright in the end. So much easier with the proper tools. š Yes sir, proper tools make all the difference in the world.
Post by rehabkymco on Jan 26, 2021 6:49:57 GMT -5
Got my parts ordered just now. Should be here by the weekend. Stage6 dash and extension Over range pulley spacer Malossi contra seat Malossi Xspecial 796mm belt
Plans for today include getting the crank, bearings and seals installed and seal the cases. Also, planning on filing my exhaust port roof to make it a bit flatter and chamfer it so the rings won't snag. To quote one of my favorite Honda youtubers, "progress is better then no progress"
Post by rehabkymco on Jan 30, 2021 13:50:18 GMT -5
Ended up dragging my feet. I've got the cpi cases mildly trenched. But haven't gotten any father. I've found another issue. It's a bit of a issue. The Primary shaft of my 15/50 has pieces of teeth missing. Now, when I put that gear set in the baccio cases, it had brand new bearings. And this is the 3rd primary gear set the Baccio has ate.
Looks like I'm either ordering another primary set, or going with stock gearing for a bit
Post by rehabkymco on Jan 30, 2021 14:06:03 GMT -5
And if I get new gears, go with another 15/50 primary for 11.282 final or put a 15/42 Secondary for 11.2 final.
Post by rehabkymco on Feb 2, 2021 9:20:38 GMT -5
Just ordered another Stage6 15/50 Primary set. Should be here by Thursday or Friday. Anyways with the snow and extreme cold this past week I haven't done anything. Really thought about playing in the snow with my Kymco. But good sense took over and I just looked at the snow. But I do want to get a couple sets of dirt bike tires for the scouts.
